Problem when i try to connect VIA Cisco vpn client through an ASA
Oct 29th, 2007
I've got this problem that just started.
If I'm sitting on the inside of my network (behind a Cisco 5510 ASA) and connect to a remote network (remote is an ASA also) it connects but wont pass traffic. If i connect my laptop to an older pix I can connect to the vpn and pass traffic. I can go to other locations and vpn int the network just fine. but when i sit behind this one specific ASA It wont pass traffic on the remote netowrk even though it connects! Anyone have any Ideas?
Pat
JORGE RODRIGUEZ Mon, 10/29/2007 - 12:46
  • Green, 3000 points or more
add this to your global polciy for IPsec pass trhough
ciscoasa(config)# policy-map global_policy
ciscoasa(config-pmap)# class inspection_default
ciscoasa(config-pmap-c)# inspect ipsec-pass-thru
ciscoasa(config-pmap-c)#exit
Jorge
JORGE RODRIGUEZ Tue, 10/30/2007 - 12:42
No problem, you should be all set but let us know if any problems..
Please rate all helpfull posts
Rgds
Jorge
