Placement of line cards 6506E
Answered Question
Oct 29th, 2007
I have a 6505E with a sup 720 in slot 5 and a 48port rj45 card in slot 1. I am adding a FWSM to the mix and want to know where I should be inserting it? I believe the fabric enabled slots are 5 & 6 but I'm not sure if that matters on the FWSM. Please advise
Correct Answer by Jon Marshall about 9 years 6 months ago
Hi William
With a 6506E it doesn't matter where you place the FWSM. The only time you need to worry is with a 6513 chassis because a 6513 chassis cannot deliver 2 x 20Gb to each slot.
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Mon, 10/29/2007 - 12:39
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Hi William
Jon
