Config for 2821 & WIC-1ADSL on AT&T ADSL
cintergis
We have a Cisco 2821 with the WIC-1ADSL which I am attempting to setup *without* PPPoE, and have had no success after following various configuration examples here on Cisco's site. I have had no trouble in the past setting this same hardware up with PPPoE.
I have confirmed the line is working with a Netopia in bridged ethernet mode so multiple static IP's could be used.
Does anyone have any recommendations for a configuration for this setup?
5 Replies 5
paolo bevilacqua
Should be like this, what do you have?
int atmX/Y
no ip address
int atm0.1 point-to-point
pvc z/k
encapsulation aal5snap
bridge-group 1
int bvi1
ip address ..
bridge irb
bridge 1 protocol ieee
bridge 1 route ip
Below are the relevent portions of the current config:
bridge irb
bridge 1 route ip
interface ATM0/0/0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0/0/0.1 point-to-point
no ip proxy-arp
bridge-group 1
pvc 0/35
interface BVI1
ip address 76.x.x.129 255.255.255.248
ATM0/0/0, ATM0/0/0.1, and BVI1 are all up & up. PVC also shows up. However, I'm still unable to pass traffic to the gateway at 76.x.x.134.
Any ideas?
Any chance they are using aal5mux on the PVC?
That would require "encapsulation aal5mux bridge".
The Netopia was using AAL5SNAP, but I went ahead and tried AAL5MUX IP on the 2821, to no avail. AAL5MUX Bridge was not available, as configured.
That is strange.. which exact IOS are you using ?
can you try disabling ip route-cache under interface and "debug ip packet", "debug arp", are interface counters increasing ?
