"no crypto isakmp nat-traversal" after reboot
Answered Question
With the ASA 8.0 software version, we've noticed that every time we reboot tha appliance, the config line:
appears in the configuration.
This is very annoying, because with this the NAT-T obviously doesn't work.
Someone of you noticed this also?
Ideas?
Thanks a lot.
Marco Pizzi.
Correct Answer by Radim Jurica about 9 years 2 weeks ago
Hi Marco,
this is bug in ASA 8.x software version and there is workaround:
CSCsj52581 Bug Details
no crypto isakmp nat-traversal inconsistent configuration after reboot
Symptom:
After a rebooting the ASA the global command "no crypto isakmp
nat-traversal"
appears within the running-config even it is not available within the
startup-config.
Conditions:
none
Steps to reproduce it:
bsns-asa5505-1(config)# crypto isakmp nat-traversal
bsns-asa5505-1(config)# copy run start
bsns-asa5505-1(config)# sh run all | inc nat
crypto isakmp nat-traversal 20
bsns-asa5505-1(config)# sh start | inc nat
After reloading the ASA:
bsns-asa5505-1# sh run all | inc nat
bsns-asa5505-1# sh start | inc nat
bsns-asa5505-1#
Workaround:
1) use a non-default value, for instance, "crypto isakmp nat-traversal 21"
2) enable the "crypto isakmp nat-traversal" after rebooting the ASA if you
need to use the default value. The default value is: crypto isakmp
nat-traversal 20
Radim
Overall Rating: 5 (1 ratings)
Correct Answer
Radim Jurica Fri, 01/04/2008 - 01:44
Hi Marco,
Symptom:
nat-traversal"
startup-config.
Conditions:
none
bsns-asa5505-1#
Workaround:
nat-traversal 20
Radim
Tee Chin Poh Wed, 12/14/2011 - 01:24
Hi Radim,
i have cofigured crypto isakmp nat-traversal 20 but it didn't appear in the running configuration. my ASA software version is 8.0(2). when i perform the sh run all | include nat.
cisco# sh run all | in nat
access-list inside_nat0_outbound extended permit ip any xxxx xxxx
no nat-control
nat (inside) 0 access-list inside_nat0_outbound
  nat-rewrite
  nat-rewrite
cisco#
so this also bug for software version 8.0(2) because i try 7.2(1) it got appear in running configuration. it can working with no issues right?
Tee
