PIX Port
Oct 29th, 2007
We have got a PIX 515E with the IOS version of 6.3(5)and got three interface which it was in use (for inside, outside and MPLS vpn)
My requirement is to establish a new Leased line from the PIX to my customer point so i need to know there is any chance of doing it with the existing setup or by adding a new ports or card
orelse we have to go for the router
Please suggest on the above issue
Vinoth
amritpatek Fri, 11/02/2007 - 17:21
This entirely depends on your network architecture, although it is good to have a router in front of PIX so that you can easily route the packets and do NAT/PAT if required. If PIX can handle extra load then you can directly connect the new network to PIX.
