SRR or WRR on Catalyst
Oct 30th, 2007
Hi everyone,
I want to do the following QoS configuration. I am having a total bandwidth of 30 Mbps.
I want to have strict priority for voice traffic with guaranteed bandwidth of 5 mb.
15 mb for SMTP traffic.
8 mb traffic need to policed so that excess traffic need to be dropped.
All other traffic should be having default priority.
What policy should I configure SRR or WRR ?
Can anyone give the configuration , also mentioning what and how the values are derived?
Any help will be highly appreciated.
Pete
Edison Ortiz Tue, 10/30/2007 - 18:17
  • Hall of Fame,
    Founding Member
QoS config depends upon the software and type of switch you are running, please post this information for further help.
dumble4me Wed, 10/31/2007 - 11:00
We are using Catalyst 4500 running 12.2(25) IOS version.
Thanks in advance,
Pete
Edison Ortiz Fri, 11/02/2007 - 06:30
  • Hall of Fame,
    Founding Member
QoS configuration on 4500 can be found here:
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/25sg/configuration/guide/qos.html
General QoS information on IOS can be found here:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cg/hqos_c/index.htm
Have a read on those documents. Understand them. Play around in the Lab.
Based on your requirements, it sounds like you are looking for a nested MQC approach.
