BOOT ON ROMMON
icbmcisco
My router 3745 boot on ROMMON mode could you help ?
Many thinks
7 Replies 7
ankbhasi
Hi Friend,
Can you check if this router has some image in flash with a command "dir flash"?
Then try manually boot command to see if it boots up.
rommon>boot
If it boots then check the "sh version" and confirm if config register value is set to 0x2102 and also verify the boot statement.
Ankur
*Pls rate all helpfull post
unfortunatly there is no image in flash
Invoke this application only for disaster recovery.
Do you wish to continue? y/n [n]: y
Ready to receive file ...
BB0BB0
Timeout waiting for data - aborting download...
It 's not workink that is the message i get
Hi Friend,
Did you tried xmodem?
Ankur
Yes i did try it already
Perhaps i can help.
1. You need a tftp server started from your PC/laptop.
2. connect cross cable from pc/laptop to the first physical interface of the router
3. assign laptop IP
4. follow url provide by Ankur
Rgds,
Christopher
