Multiple dynamic-to-static l2l on ASA???
Oct 30th, 2007
I'm wondering if is it possible to have more than one dynamic-to-static l2l VPN on ASA running 8.0(2) with IOS router as branch.
It seems I can have just one VPN up and running at the time; since another VPN connect to the ASA, the first one stops to work, then after a while the new VPN stops to work and the first one came back...the tunnel is never to became 'tunnels', is just bouncing beetween the two branch.
Anyone knows if there are limits to the design I'm trying to deliver?
Thank you for any kind of help.
Iacopo.
