CDR Error
Oct 30th, 2007
i have found one error when i go to CDR report and analysis in my publisher server is
Warning : In some servers in this cluster the CDR Enabled Flag is false and so CDR entries may not be generated for all the calls made in this cluster.
and i have not found any CDR Service activation option in Subscriber.
plz give me solution
Overall Rating: 5 (1 ratings)
Rob Huffman Tue, 10/30/2007 - 06:27
Hi Jay,
Have a look at your Subscriber Server (Services) and ensure that you have the following set to True;
CDR collection is enabled through the CDR Enabled Flag Cisco CallManager service parameter
CDR Enabled Flag-Cisco CallManager service parameter that controls whether CDRs are generated. Set this parameter to True on each Cisco CallManager in the cluster. You do not need to restart the Cisco CallManager for the change to take effect.
From this good doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00803edb2b.html#wp1031481
Hope this helps!
Rob
Please remember to rate helpful posts.....
jay_bharti Tue, 10/30/2007 - 07:02
Hi Rob
thnx for Reply
but my main problem is i cant find any option
like
"CDR Enabled Flag" in Cisco CallManager service parameter in both publisher and subscriber. In both server Os administration window showing both are publisher in cluster menu..
plz give me reply..
Rob Huffman Tue, 10/30/2007 - 07:51
Hi Jay,,
I remember now reading your post from the other day on this 2- Publisher issue. I really think that you should open a TAC case on this one. You will have nothing but problems going forward if you leave both servers thinking that they are the Publisher. I think this CDR problem will seem mild compared to trying a Database Restore or other normal operations with this config left "as is".
Sorry, but this is really the way to go,
Rob
