IDSM-2 Re-Image
Oct 30th, 2007
I've ran in troubles after IDSM booted up into maintenance partition. IDSM-2 is refusing session from switch running native IOS and unresponsive. Any quick solution for this problem? TAC is the only resort / could be a HW problem?
1#ses slot 2 proc 1
The default escape character is Ctrl-^, then x.
You can also type 'exit' at the remote prompt to end the session
Trying ...
% Connection refused by remote host
Mod MAC addresses Hw Fw Sw Status
2 0003.xxxx.xxxx to 0003.xxxx.xxxx 4.0 7.2(1) 1.3(2)m Ok
irisrios Mon, 11/05/2007 - 07:14
There is no problem with the hardware. Changing the boot parameter from cf:1 to hdd:1 worked for me 1.e from Flash to hard disk
