Warning message
Remote VPN Client cannot ping the LAN resources
Oct 30th, 2007
I got a Cisco VPN Client Initiating a VPN connection behind an ASA Firewall(8.0.2) to a PIX (7.0) across the internet , the VPN is establish with IP but cannot ping the resources behind the PIX.
With the VPN client behind any internet cafe/starbucks, its able to establish and ping the resources behind the PIX.
Any suggestiongs?
Patrick.Beaven Wed, 10/31/2007 - 11:27
If youre ASA has the IPS module installed it could be the global inspection policy.
You could troubleshoot it bye either removing the global inspection policy or adding.
Policy-map global_policy
class inspection_default
inpect ipsec-pass-thru
exit
This information was given to me in this forum and it fixed the issue.
r-docuyanan Wed, 10/31/2007 - 22:58
Hi After checking the logs here is what i found
After checking on the log i found like following error
3 Nov 01 2007 12:07:24 305006 22X.255.66.X regular translation creation failed for protocol 50 src inside:10.10.10.160 dst outside:222.255.66.230
htaluja_2 Sun, 11/04/2007 - 00:16
Looks like the return traffic is NATTed on the way back. Make sure you have a nat 0 access list with source ip as your lan addresses and destination ips as your vpn client ip pool. Hope this helps.
