10-30-2007 06:00 AM - edited 03-03-2019 05:33 AM
Let's say I have a cisco switch and I want to program it to have some V-LANs how do I go about doing that.
10-30-2007 07:28 AM
Hi Friend,
You can create vlans using the commands below
Switch# configure terminal
Switch(config)# vlan 20
Switch(config-vlan)# name test20
Switch(config-vlan)# end
This link will give you more details on the same
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3750/12240se/scg1/swvlan.htm#wp1150876
Ankur
*Pls rate all helpfull post
