QCT with CCME 4.2
Oct 30th, 2007
Dear Voice Experts
Try to configure a CCME 4.2 on a router 2821 with latest QCT version 3.0.1 cause it would reduce a lot of work for command configuring.
But always get problems that none of the included phones in QCT are compatible to CCME 4.2
Any suggestions - cause i thought workaround will be to downgrade IOS for QCT of 4.0
But that's not really an longterm solution.
Do you plan to publish a new QCT Version ???
Many thanks and greets from Vienna
Helmut Schranz
[email protected]
hadbou Mon, 11/05/2007 - 09:54
Upgrading to lastest version of CME 4.2. or later will help run the archive command for GUI files.
Paolo Bevilacqua Mon, 11/05/2007 - 14:33
Hi Helmut,
you will find that the thing that cisco does better, for sure is NOT gui / PC-based tools / etc.
These appears to be provided more to pass a "check-mark" on some tender requirements sheet, more than to be of real use.
So don't hold your breath for new improved versions, prepare solid config template and perhaps some custom text-based tool to help your repetitive configurations.
