Problems with QPM on Frame Realy
Oct 30th, 2007
Hi IVE GOT THE QPM tool but al my WAN links are frame relay, in all off them im applying the policy-map on the DLCI interface but the tool it does not recognize the entire Frame Relay Cloud, can anyone can help me guys?
jsivulka Mon, 11/05/2007 - 09:59
  • Bronze, 100 points or more
Currently QPM does not support the frame-realy dlci commands, only map statement commands.
cesarbetancourt Mon, 11/05/2007 - 13:55
That means that i cant monitore task asosiated with frame relay, i hope you can help me because is the only place that im reciving info about this issue
regards
