VLAN on Subinterfaces on a 2621 Router
Oct 30th, 2007
I have a 100Mb leased line with a 2621 router at each end. I want to span vlan's across this line and have created subinterfaces on the fa0/0 interface on each as follows:
interface FastEthernet0/0
no ip address
speed 100
interface FastEthernet0/0.50
encapsulation dot1Q 50
ip address
interface FastEthernet0/0.254
encapsulation dot1Q 254 native
ip address
interface FastEthernet0/1
ip address
speed 100
The config is the same at both side, but with a different IP address in the same subnet range.
I can now ping between the ip addresses associated with the subinterfaces on the native vlan, but I cannot ping between those non-native vlans.
Any ideas?
Thanks in advance.
Paolo Bevilacqua Tue, 10/30/2007 - 14:12
you need to ask your metro SP to carry 802.1q. They need to support what is called "Q-in-Q".
campbell.thomps... Wed, 10/31/2007 - 03:25
I got excited about that, but alas no, I spoke to the SP and it's fibre with little in the way of hardware in between.
I'm at a loss...
Paolo Bevilacqua Wed, 10/31/2007 - 04:58
Do they only have media converters to present you the circuit over copper? Positive not even a switch in between ?
Easy check to confirm switch presence is that if you unplug one side the other stays up.
campbell.thomps... Wed, 10/31/2007 - 05:12
Yes, just media converters.
Is there anyway I can debug at packet level to make sure the reference is the same at both sides?
Paolo Bevilacqua Wed, 10/31/2007 - 07:02
this is supposed to work as configured. You can attached a to PC with analyzer to confirm the router is sending the correct encap. Note you need a NIC driver with support for 802.1q to see tagged frames on the PC (not all NICs are like that).
campbell.thomps... Wed, 10/31/2007 - 07:05
Okay, managed to get it working, but I needed to change the encapsulation on the outside port on each router from dot1q to isl... Very weird...
Any thoughts on why this would work?
