Terminal monitor issue with 3750
Answered Question
Oct 30th, 2007
I'm having an issue with term mon not displaying messages. I enable term mon on telnet connection and have checked the log settings and monitor is set as debugging. I am mainly interested in seeing line up/down status so I set a couple of interfaces logging event link-status. Maybe I've misunderstood how to do this. Thanks for the help.
Correct Answer by Edison Ortiz about 9 years 3 months ago
Ok, term monitor is now enabled and you should receive any messages sent to console. If you don't, is due to lack of messages being generated :)
As for the command I posted; is basically the same command you typed (show term) but grepping for that line only.
Overall Rating: 5 (1 ratings)
Edison Ortiz Tue, 10/30/2007 - 18:22
Do you have logging console enabled ?
If you connect via the console cable are you able to see those messages ?
Terminal Monitor is simply console messages redirected to your telnet session.
bava_ccna Wed, 10/31/2007 - 00:17
I am not getting any messages after enabled debug ip ospf hello from my telnet session to router 3660 even my serial int goes down it is not showig me any alerts.
How can i enable it? Plz help
Edison Ortiz Wed, 10/31/2007 - 06:29
I'm sorry, Are you the same person as the original poster ? The thread is about a 3750 switch and you are posting about a 3660 router.
If you are not the original poster, please open a new thread to avoid any confusion.
glen.grant Wed, 10/31/2007 - 05:07
Use logging event link-status default command and also do you have snmp traps setup for link up/down ?
jstewart33 Wed, 10/31/2007 - 09:41
I checked and console logging is enabled. I set logging event link-status on a couple of interfaces. When I do show logging I see that all logging is enabled. The only message I ever see on the screen when I telnet is configured from console by vty0.
Edison Ortiz Wed, 10/31/2007 - 10:01
I'm trying to isolate the problem from term monitor vs console messages.
If you console into the switch with a direct console cable, are you able to see those messages ?
Can you post show term output while telnet into the switch as well as show logging ?
jstewart33 Wed, 10/31/2007 - 11:21
I cannot connect with a console cable because this stack is in another physical location so I cannot say for sure if messages are being displayed on the console. I've attached term and logging output.
Edison Ortiz Wed, 10/31/2007 - 12:17
Based on the output, you don't have terminal monitor enabled:
Capabilities: none
Here is my output:
Rack1SW1#sh term | i Capa
Capabilities: none
Rack1SW1#term mon
Capabilities: Receives Logging Output
jstewart33 Wed, 10/31/2007 - 13:03
Here's the new output with term mon in enable in case they were different. What does sh term | include Capabilities command do? I'm unfamiliar with that command.
Correct Answer
Edison Ortiz Wed, 10/31/2007 - 13:16
