Command sh controller to detect line speed
Oct 30th, 2007
If I perform the following command on a cisco 72xx series, I get an output which is showing me the speed the serial port is getting from the Csu/dsu.
The same command performed on the cisco 17xx; 18xx;26xx;28xx series never showes the clockrate. Is it impossible to get it or there is another way? Since sometimes Ptt set wrong speed on the csu/dsu it could be important check on the router which speed is detecting
7206vxr#sh controller s2/5
M8T-V.35: show controller:
DCD=up DSR=up DTR=up RTS=up CTS=up
line state: up
cable type : V.35 DTE cable, received clockrate 2047212<<<<<<<<<<<<<<<<<<<<<<<
Overall Rating: 3 (1 ratings)
Paolo Bevilacqua Tue, 10/30/2007 - 10:45
received clock measured is available only on certain HW interfaces. There is no way to obtain the clock info where not supported.
