applying service policy using radius and VPDN
Oct 30th, 2007
anyone had any success doing this?
I've been following the suggested config at http://www.cisco.com/en/US/customer/products/ps6566/products_feature_guide09186a0080610dad.html#wp1058626 but not having any success.
sessions terminate on my 7301 via L2TP through another provider - this all works fine.
I have the following AVPair defined in the user RADIUS profile:
Cisco-AVPair = "ip:sub-qos-policy-out=DROP-P2P"
and the matching policy map defined on the 7301 but it does not get applied to the user session.
Debug L2X errors gives the following message:
001867: Oct 30 16:12:50.655 UTC: L2X: Unknown AVP 76 in CM SCCRQ
001868: Oct 30 16:12:50.655 UTC: L2X: Ignoring unknown AVP 76
if I apply the policy map in the virtual-template it does get applied, but obviously to all users on that template which is not what I want.
edit: - btw the 7301 is on 12.4 so this feature should be available.
thanks
Liam.
liamkennedy Tue, 11/06/2007 - 04:30
thats the same document I referenced in my original question and its states clearly "You can choose to configure the feature using either a virtual template or a RADIUS server."
If you add the policy to the virtual template it will apply to all users, if you use RADIUS you (should) be able to apply policies on a user-by-user basis.
