chris.damore Tue, 10/30/2007 - 09:45
I am trying to setup transfer directly to voice mail. I don't understand what application would tie to CTI?
Rajesh Revuru Tue, 10/30/2007 - 10:29
For direct transfer to voicemail. Just create a RP, and create *XXXX (if you are using 4 digits) and forward all the calls to VM pilot.
That should do it.
Rajesh Revuru Tue, 10/30/2007 - 11:54
As shankar & rob suggested, CTI RP in this one it wouldnt register.
CTI RP only registers with Mobility MAnagaer, IPMA & Attendant Console
