How to send a mail from a DMZ ...
Oct 30th, 2007
I have this configuration on my ASA :
- outside (WAN) : 10.0.0.254
- inside (LAN) : 192.168.100.254
- dmz : 192.168.110.254
In my DMZ, I have a https server which can be accesible from internet. So I have created a nat rule to redirect the port 443 :
#> sh run static
static (DMZ,WAN) tcp interface https 192.168.110.1netmask 255.255.255.255
Moreover I have created a rule in the security policy to permit the https connection from WAN to DMZ.
My problem is that the https server can't send a mail from the DMZ. I have created this rule in the security policy but without effect :
server 192.168.110.1
in the DMZ
on the port any
TO :
any
in the WAN
on the port 25
ACTION : permit
When I do a telnet on the port 25 of a smtp server, I have a message TCP TIMEOUT in the live log.
What is the problem ?
Thanks for your help
Collin Clark Tue, 10/30/2007 - 09:37
  • Purple, 4500 points or more
Your acl is something like this?
access-list dmz_to_outside permit tcp host 192.168.110.1 any eq 25
I would check a couple of things: How and where is the acl applied? Will you need DNS? Check the hit count on the ACL.
mathieu47 Wed, 10/31/2007 - 01:51
I have created your access-list rule without effect ... I try to answer to your questions (sorry, I an a novice in cisco management)
1) How and where is the acl applied ?
I don't know !!! In fact, I think that I don't really know what the acl is !!! Is it the same think that the security policy ?
2) Will you need DNS ?
Yes. But DNS isn't a problem because I have created rule to check dns in my LAN and the DNS requests are OK (for example with a nslookup on my server)
3) Check the hit count
What is the hit count ?
Sorry for my gaps !!!
mathieu47 Wed, 10/31/2007 - 03:44
I have solved my problem !!! I have created this nat rule :
static (DMZ,WAN) 10.0.0.100 192.168.110.1 netmask 255.255.255.255
Then I have created 2 rule in the security policy to open the ports 443 and 25.
So the server is accessible from internet and it can be send email !!!
