Line Privacy - CME/UC500 Series
Oct 30th, 2007
In my research, I was unable to find line privacy supported in CME/500, but I did find it supported in Call Manager. Does anyone know if this can be done in CME/UC500?
Rob Huffman Tue, 10/30/2007 - 14:08
Hi Jay,
Sadly, as you have discovered Privacy for "Shared Lines" is not yet supported on either CME or UC500.
Sorry about that,
Rob
jay.r.floyd Tue, 10/30/2007 - 14:16
Rob,
Thanks for the response. Well, to add to the confusion, I was able to obtain a CM/CME descriptions matrix rev 2.0 that indicates under line features, privacy support for both CME 4.0 and CM 6.0 (plus all older releases).
I will try to enable it in our lab, until I see it work…
Rob Huffman Tue, 10/30/2007 - 16:26
Hi Jay,
That is curious isn't it :) Generally in CCM Barge and Privacy are referred to in conjunction with each other. Privacy prevents a Shared Line user from "Barging" in on an active call. Maybe they are referring to something else as Barge is not supported on CME either.
This is an excellent reference;
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_configuration_guide_chapter09186a00807f6fa8.html
Hope this helps!
Rob
