secondary number in ephone-dn
Oct 30th, 2007
Hi All,
I am using CME 4.1 with PRI connection. all ephone-dn are dual line with secondary number. I can't define dialplan-pattern becasue DID with extension is not match.
ephone-dn 1 dual-line
number 337 secondary 9495025006
when I make a outbound call to PSTN, CME sends 337 instead of DID, therefore call fails. is there any way to send DID to PSTN without to change the order of extension and DID in ephone-dn? because there are lots of ephone-dn and take forever to change this order.
thanks
Alex
Paolo Bevilacqua Tue, 10/30/2007 - 10:07
If you want them to send PSTN number then you need a translation rule, and / or num-expan.
alex goshtaei Tue, 10/30/2007 - 11:04
thanks for your reply,
I can't use num-exp because DID with extension is not match, for example 327 as extension and 9495025007 as DID. also If I want to use translation-rule, I have to define 155 translation rule for each ephone-dn. is there any other way to tell to CME send secondary number (DID) as calling number?
thanks
ALex
