CiscoWorks question
Oct 30th, 2007
I want to run the enable secret $x6E8s# by Ciscoworks, but it gives me the following error message:
enable secret ********
can't read "x6E8s": no such variable
Any reason?
Overall Rating: 4.7 (5 ratings)
Joe Clarke Tue, 10/30/2007 - 10:09
LMS uses the '$' to indicate a variable for parameterized templates. How are you creating this job, and what version of RME are you using?
persepolis77 Tue, 10/30/2007 - 10:16
RME version 4.0.5
I do not understand what you mean by how I create the job, but I have a template which has the following command:
Should I add something before $ to show that $ is a part of my password?
Joe Clarke Tue, 10/30/2007 - 10:22
If you have a template, check its configuration to see if you've checked the "Parameterized" box. If so, uncheck that box, and save your user-defined task, and see if that helps.
persepolis77 Tue, 10/30/2007 - 10:31
"Parametrized" is not checked. I will check it and try again to see it that one helps or not.
I actually have another problem also. I have the following command in tclsh:
proc get_net { interface } {return [join [lrange [split [lindex [exec sh ip int brief $interface
| include $interface] 1] .] 0 2] .]}
and I get this error message:
+>missing close-brace
In my template, the line is complete!!!
Joe Clarke Tue, 10/30/2007 - 10:37
Do not check it as it will certainly not do what you want. This may be a bug in RME 4.0.5. I tested 4.1, and your template is working.
As for the TCL problem, please start a new thread in the Network Management forum for that.
Joe Clarke Tue, 10/30/2007 - 10:44
I tried RME 4.0.5 with your template, and it works just fine if I don't check the Parameterized box.
What I did was create a new User-Defined Task in Netconfig. The Task was a Config Task for Switches and Hubs (I tested with a 3560). I did NOT check the Parameterized box, and I entered, the following in the CLI Commands box:
I then went to NetConfig Jobs, and created a new job to deploy this template to my test 3560. It deployed just fine. No errors.
persepolis77 Tue, 10/30/2007 - 12:01
I created a new template with only enable secret command and it worked for me also, but when I add it to all my config, it does not work!!!
Any idea why?
Joe Clarke Tue, 10/30/2007 - 12:03
What do you mean, it does not work when you add it to your config? Are you getting the same error as before?
persepolis77 Wed, 10/31/2007 - 06:36
yes, true, it was not working when I added it to my config!!!
but, I found the problem. When I was changing my enable secret, I was still in TCL mode. That is why whatever was after $ was considered as a variable.
I just put my enable secret after the exit of TCL mode and it worked.
