Device Discovery
Oct 30th, 2007
The device discovery will show that it found the device, but it will show it as unreachable and it wont add it to the DCR? I verified the snmp settings on the switch and in the snmp settings for device discovery. If I go in and manually add the device (with the same snmp settings) in the dcr, it adds just fine.
Overall Rating: 3 (1 ratings)
David Stanford Tue, 10/30/2007 - 10:11
  • Cisco Employee,
Do the snmp strings on the device match those of snmp settings in CM itself?
Any filters in CM that prevent it from adding the device to DCR?
tsmarcyes Tue, 10/30/2007 - 10:23
Verified snmp settings. Fresh install and havent applied any filters.
