External Online Indicator
paolo bevilacqua Tue, 10/30/2007 - 11:24
  • Hall of Fame,
    Founding Member
That is not easy! Are you willing to open the phone for a mod ?
Perhaps something very complicated can be built using an application and the light connected someway to a PC.
paolo bevilacqua Tue, 10/30/2007 - 15:09
  • Hall of Fame,
    Founding Member
Quite a bit of time. You need a small relay box to pilot the light, depending on the load. if it was a 7961 I would try to hook into the line led, that is the only gauranteed to lit no matter phones is used with receiver, speackrphone, or headset. Bute the 7960 buttons do not lit so I guess your only chocieis the hoockswitch.
Good luck!
