Weird Problem! Cisco 2950
Oct 30th, 2007
Hi, I really dont know if this issue is applicable here but I am desperate for help now. We have a wireless project providing internet access in a very remote location. There are wireless mesh accesspoints connected back to back by wireless Point2MultiPoint Links (P2MP). I have 2 BSU (Base Station Units) each connected to 3 CPEs. The 2 BSU's are connected to zero configuratoin 2950 switch.Below is a brief on the technical scenario:-
1. Wired backhaul subnet
2. DHCP Relay
The problem is that when I connect both the BSU to the switch they perform well. But after 10-15 minutes the other BSU ( starts giving huge delays and finally times out. Disconnecting the stable BSU ( from the switch brings the other one up. The switch already has STP enabled.
Is there a loop in the network? Any problem with the BSUs? Are the Mesh Access Points broadcasting? How do I troubleshoot this? Your valuable comments, suggestions will definitely get me somehwere.
Attachments: network scenario, ping snapshots of the BSUs.
dennischolmes Tue, 10/30/2007 - 12:12
I need a whole lot more information. What model number of aceess points, controller code, and distance between MESH units just to start.
sarfarazkazi Tue, 10/30/2007 - 23:28
Hi Dennis,
We are using Tropos 5210 Mesh Routers as Access Points and a Colubris 3500 Controller for a portal page.
The distance between each mesh unit is more than 50 metres.
dennischolmes Wed, 10/31/2007 - 04:06
Can't really help you there. I don't know the Tropos or Colubris products well enough to assist. I suggest you call their tech support.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
