10-30-2007 10:59 AM - edited 03-13-2019 04:37 PM
Hi!
I have almost successfully configured Mobile Connect for CUCM 6.0, but I have one issue: When the rerouted call goes to the PSTN the calling number is not translated, independently of the calling party transformation mask, configured for the route pattern. When the ordinary call goes out using the same route pattern, the calling numer transformates.
Any help will be very appretiated.
Thank you!
Solved! Go to Solution.
11-05-2007 01:50 PM
You should be able to use the "Transformation Patterns" under the "Route PLan" menu (not to be confused with "Translation Patterns"
11-05-2007 11:23 AM
Translation Pattern:
- Used to translate called (DNIS) and calling (ANI) numbers before routing the call. For example, a call may come in to a set of numbers 919 392-3XXX that need to be translated to a set of IP phones that are in the range of 2XXX. The CallManager has a Translation Pattern set up for 919 392-3XXX.
This pattern translates the leading 919 392-3 simply to 2 while leaving the remaining digits intact. Then the call is routed to the appropriate IP phone. Translation Patterns are used only for true translations and should not be used for simple digit stripping and prefixing.
11-05-2007 01:50 PM
