CAD Agent To Agent Transfers
Oct 30th, 2007
Can anyone point me to a manual that says how to setup Agent to Agent transfers in CAD?
I have my agents associated to a Team, which is mapped to dialed number 9999, which is mapped to a routing script that uses the Queue to Agent Node.
We have a CTIOS app that when you hit the agent transfer button, it prompts you for your 4 digit agent id, then behind the scenes it knows to dial your team extension and append the 4 digits you just added and make the transfer.
Not sure how to do it in CAD?
Thanks for your help!
jasonprescott Thu, 11/01/2007 - 07:36
With CAD, I think that you are going to have to send those calls to a translation pattern in the call manager or to a routing script the can replace the digits. I don't know of any way to change the programming of the transfer button in CAD as you were able to in CTIOS.
What we did for a similar issue was that we created a dialed number of ##XXXX, and trained our agents to dial ##XXXX when they wanted to transfer calls between centers. ##XXXX can then go to a script that can look up the team that the agent is associated with and append the appropriate digits.
d.menkel Thu, 01/24/2008 - 18:13
I wanted to join in this discussion to ask a few questions.
How do you map a number to a team?
Can you pass enterprise data in an agent to agent transfer?
I have a customer that wants queue statistics via historical reports on a agent to agent transfer.
