10-30-2007 02:01 PM - edited 03-03-2019 05:34 AM
I have a client with multiple sites (& Cisco routers). Most of the sites (spokes) have just one ISP connection, however one of the sites (the hub) has two ISP connections. I'd like to create two tunnels between the spoke-and-hub sites and only send certain traffic (eg: RDP and Telnet) through one tunnel and everything else through the another tunnel. (for simple load balancing purposes)
Is there any easy method to do this?
eg: I'm thinking of any traffic that matches an access-list, set the "next hop" to the endpoint of one tunnel, but I'm not sure exactly how to do that.
any suggestions?
Solved! Go to Solution.
10-30-2007 03:46 PM
Correct,
Make sure to apply ip policy route-map redirect_to_tunnel in the ingress interface.
10-30-2007 02:11 PM
Source-Based Routing is done via PBR.
Please take a look at this document:
Play around with it in a lab and post back if you have any more questions.
10-30-2007 02:49 PM
OK, so something like this should work?
access-list 101 permit tcp any any eq 3389
access-list 101 permit tcp any any eq Telnet
route-map redirect_to_tunnel permit 10
match ip address 101
set ip default next-hop 172.16.0.1
So anything that doesn't match the access-list 101 will get processed normally (it will go to the default tunnel), but packets that DO match the access list will get redirected?
10-30-2007 03:46 PM
Correct,
