Reverse SSH via Console port
Oct 30th, 2007
when setup a reverse ssh to console port, what is required to get this to work.I have in the router 16-port asynchronous/synchronous serial network with High-density 8-port EIA-232 asynchronous EIA-232 asynchronous. I have read some of the documentation on setup a console ssh. I have setup individual lines with rotary groups as 1 for all the lines, and configured ip ssh port 2000 to 2007 with rotary 1 and configured login auth, no exec transport input ssh.
When I testing I uses putty ie 192.168.16.22 port 2000, I get a reponses back from the router not the device at the end of the 8 port density octal cable.
Overall Rating: 1 (1 ratings)
ebreniz Mon, 11/05/2007 - 11:56
Connected router Aux to console via rollover cable. execute the following on the router:
show line revealed line 65 to be the aux port
ip host bar01 2065 172.21.130.2
line aux 0 transport input telnet
