Aironet 1200 - Wont start up (three green LEDs)
Oct 30th, 2007
Hello, I am having a problem with my Aironet 1200 not booting up. It was previously starting up ok, but I was having problems access it through web browser and so I reset it using the mode button and plugging in power. Ther Aironet now starts up to the point that all three of the LEDs are green and stays like this. I have tried to reset it again without any luck.
According to the documentation :
Green, Green, Green = Starting Cisco IOS.
As it never progresses from this, I am at a loss at how to fix my problem. Any advice would be appriciated.
andrew.brazier@... Wed, 10/31/2007 - 09:30
  • Bronze, 100 points or more
If you connect a console cable what appears as the AP powers on?
rmawatson Sat, 11/03/2007 - 00:42
Just recieved my console cable. The access point halts at this stage.
System ID: 000D65B54684
Motherboard: IBM405 200MHz, 8192KB FLASH, 16384KB DRAM, Revision 04
Bootstrap Ver. 1.00: FLASH, CRC 1C914641 (OK)
Initialization: OK
_
Any ideas ?
Scott Fella Sat, 11/03/2007 - 09:29
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
If that is all you get from the console, then your AP needs to be RMA'd.
Rob Huffman Sat, 11/03/2007 - 09:44
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
    2017 IP Telephony, Unified Communications
Hi Robin,
It sounds to me like the IOS was erased by using the reset/mode button :(
You can load a new Cisco IOS release using TFTP.
Follow these steps for loading a Cisco IOS release using a TFTP server:
Step 1 The static IP address of the PC on which your TFTP server software runs should be between 10.0.0.2 and 10.0.0.30.
Step 2 Make sure that the PC contains the access point image file (such as c1200-k9w7-tar.122-15.JA.tar for a 1200 series access point) in the TFTP server folder and that the TFTP server is activated.
Step 3 Rename the access point image file in the TFTP server folder to c1200-k9w7-tar.default for a 1200 series access point, c1130-k9w7-tar.default for an 1130 series access point, and c1240-k9w7-tar.default for a 1240 series access point.
Step 4 Connect the PC to the access point using a Category 5 (CAT5) Ethernet cable.
Step 5 Disconnect power from the access point.
Step 6 Press and hold MODE while you reconnect power to the access point.
Step 7 Hold the MODE button until the status LED turns red (approximately 20 to 30 seconds) and then release.
Step 8 Wait until the access point reboots, as indicated by all LEDs turning green followed by the Status LED blinking green.
Step 9 After the access point reboots, reconfigure it using the GUI or the CLI.
From this doc;
http://www.cisco.com/en/US/products/hw/wireless/ps430/prod_technical_reference09186a00804fc3dc.html#wp161272
Hope this helps!
Rob
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
