Maximum phones hosted for different MCS servers
Oct 30th, 2007
I'm looking for a matrix that will tell me how many phones a server model is able to handle under CallManager 4.2(3) and 5.1(2). I can't seem to find one, can someone point me in the right direction?
rob.huffman Tue, 10/30/2007 - 16:40
Hi Shikamaru,
There is not one single doc (matrix) that contains all this info :(
This doc shows the Server support for all CCM Versions;
This link is for all available MCS Servers and shows the number of supported phones for each model;
Hope this helps!
shikamarunara Tue, 10/30/2007 - 16:44
Yeah, I found these too. You'd think that the maximum phones supported would also depend on the version of CM being used, no? CCM 5.1 has higher reqs than 4.2. I wonder why it doesn't change?
