Clear Connection statistics WAE
Oct 30th, 2007
How do we clear connection stats in monitoring option in WAE ? I went to CLI and run "clear statis all" but could not clear "connection summary table" in "monitoring" display.
thanks
Serhat
Zach Seils Wed, 10/31/2007 - 13:04
  • Cisco Employee,
Serhat,
The connection summary table shows a list of currently active connections. There is no way to clear the list without closing the connection(s).
Zach
s.uslay Wed, 10/31/2007 - 15:04
thanks Zach, another improvement that can be made in GUI in addition to others ..
Serhat
s.uslay Wed, 10/31/2007 - 16:49
I don't think this connection summary screen is reflecting what has been happening. I have disconnected the link (all sessions broken), it still shows connections that started 11 and 6 hours ago.Besides, I am running Netflow in the branch router that shows 64 MB of Notes traffic sent to the branch but connection summary does not have any stats on it. I might report this to TAC.
10.64.191.40:2358 10.64.101.151:42510 waasdcp1 11:19:13 36.5117 KB 22.623 KB 38%
10.64.191.15:32873 10.64.101.151:27010 waasdcp1 6:45:20 28.2832 KB 9.5088 KB 66%
10.64.241.130:2418 10.64.191.21:445 waasdcp1 0:30:17 19.1846 KB 12.1631 KB 37%
10.64.218.91:1602 10.64.191.21:445 waasdcp1 0:21:14 13.6436 KB 8.0693 KB 41%
10.64.102.76:1927 10.64.191.21:445 waasdcp1 0:21:1 26.7871 KB 16.7832 KB 37%
10.64.241.105:2145 10.64.191.21:445 waasdcp1 0:14:22 8.8232 KB 7.4648 KB 15%
Zach Seils Wed, 10/31/2007 - 18:57
  • Cisco Employee,
For how long were the connections displayed after you "broke the link"? If the WAE interface goes down, the regular TCP keepalive timeouts don't apply, instead a write timeout applies. The write timeout has no set limit, but is rather based on TCP's retransmission timeout that is dynamically adjusted based on link's RTT. We try to send the backlogged data up to 15 times at exponentially backed off intervals with a max limit of 120 seconds, and in the end, we declare a write time out and close the connection with an active reset.
Zach
eng.usama Thu, 11/01/2007 - 01:40
i have the same problme also when i want to clear staticts of last week and start staticts from new point i tried "clear statics all" and when i went GUI and choose monitoring i found result of last week and last day i want clear this result
Zach Seils Thu, 11/01/2007 - 07:16
  • Cisco Employee,
The command 'clear stat all' clears the statistics in the WAE CLI, not the Central Manager. The CM is a repository for historical statistics.
The connection listing can't be cleared. It is a list of currently active connections.
Zach
s.uslay Thu, 11/01/2007 - 16:03
even clearing the "stats all" in CM is not clearing connections stats in the individual devices.As you suggested, this connection listing can not be cleared. The thing I don't understand how come two connections in the display stayed up even after I broke the WAN link.May be the developers can put an option to clear the connection stats in the next releases.It is frustrating for the customer.
Serhat
Zach Seils Thu, 11/01/2007 - 16:06
  • Cisco Employee,
Did you see my previous question? How long do they stay there? Indefinitely?
Zach
s.uslay Thu, 11/01/2007 - 16:12
sorry Zach, I missed your question. One particular connection is still up even though the server was moved to another site last night. Even "refresh" is not clearing it.
Serhat
Zach Seils Mon, 11/05/2007 - 06:59
  • Cisco Employee,
Can you please provide the output from the following command for one of these connections:
sh tfo conn
Zach
s.uslay Mon, 11/05/2007 - 15:19
Zach,
The output is attached. The "sh tfo conn" display shows different "open duration" than the gui output. I have shown both in the file.
I also had problems clearing out filters once it is in place. I had to do several "reset sort"s to clear the filters.
Serhat
Zach Seils Mon, 11/05/2007 - 22:44
  • Cisco Employee,
These connections don't look stuck, so much as there is a discrepancy between the start time shown in the CLI and the duration in displayed in the CM.
Do you see this discrepancy for all of the connections?
Can you provide the same output again, but also include the peer WAE and the 'sh clock' output from both WAEs and the CM?
Zach
s.uslay Tue, 11/06/2007 - 15:43
Zach,
The connection has been dropped so many times but the first two connections stayed in the display. In the central device there are some connections that show 200 hours uptime certainly not correct especially after the connection recycled several times.I will stop spending time on this one, thanks for your support.
Serhat
eng.usama Wed, 11/07/2007 - 14:37
i think this issue may caused due to system.monotoring.collect rate which remote WAEs send its staticts to centeral manager its default 60 so when connection in remote sites terminated the centeral manager know that after 60 or less (when remote waes send to c.m its staticts)so when you do sh tfo stat (in remote wae) and compare it to c.m it must not be the same
Zach Seils Wed, 11/07/2007 - 15:19
  • Cisco Employee,
Actually, the list of connections is queried directly from the WAE when you select that option in the contents pane. You can refresh the list by clicking on the "Refresh" button.
Zach
