Phone Dev Pack in CallManager SR5b
Oct 30th, 2007
I want to install CallManager SR5b but I do not want to install the Dev pack that is included in it.
Is there a way to prevent the Dev pack that is included from installing?
Overall Rating: 2 (1 ratings)
pklos Wed, 10/31/2007 - 19:22
  • Silver, 250 points or more
You can install sr5d, but still control 'device defaults'. Write down defaults, next install your SR and re-set them after installing sr5b (but I think you should install sr5d).
regards,
pk
Live2 Bicycle Thu, 11/01/2007 - 06:08
Yea, I knew I could take a screen shot of the CCM Device page and before the final reboot of the app upgrade change the firmware loads back to what they were previously.
I have seen a couple of bug reports on 5b regarding phone loads. They have included those is 5D. The upgrade starts in 8 hours. I hae both b & D on the server. We will most likely go with D.
