https in AP1240 fails
Oct 30th, 2007
Greetings.
My AP1240AG runs 12.3.11-JA4 code, works fine, but I can't enable https on it, SSH is working fine. I need both https and SSH both.
I've tried the same config on my 1231BG units, and that works perfectly with the same config.
Anyone heard of this problem with the 1240's?
Thanks, Jeff
Rob Huffman Wed, 10/31/2007 - 06:12
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Jeff,
I think you may be hitting this bug;
CSCsi92058-HTTPS access to the access point does not work after upgrading to Cisco IOS Release 12.3(11)JA.
Resolved in;
Release Notes for Cisco Aironet Access Points and Bridges for Cisco IOS Release 12.4(10b)JA
http://www.cisco.com/en/US/docs/wireless/access_point/ios/release/notes/12_410b_JArn.html#wp272052
Hope this helps!
Rob
Trending Topics - Security & Network
