Configure Interesting Trafic on Virtual-PPP
Oct 30th, 2007
I ve configured L2tp from Cisco 870 via Pseudowire to my SP and the traffic is routed via Virtual-PPP interface. VPDN tunnel is coming up always. But i want the tunnel to be "UP" only when there is an interesting traffic routed on Virtual-PPP1. I tried by configuring "ppp idle timeout" but tunnel is coming up every 10 secs. Is there any way to configure so that VPDN tunnel comes up only when the interesting traffic hits the Virtual-PPP interface.. Attached is the config:
l2tp-class test
hostname LAC
pseudowire-class test
encapsulation l2tpv2
protocol l2tpv2 test
ip local interface FastEthernet4
interface Virtual-PPP1
ip unnumbered Loopback0
ip route-cache flow
load-interval 30
no cdp enable
ppp pap sent-username java.util.regex.Matcher[pattern=[a-zA-Z0-9_+-.]+@[a-zA-Z0-9][w.+-]+.[a-zA-Z]{2,} region=0,955 lastmatch=[email protected]] password xxx
ppp timeout idle 30 either
pseudowire x.x.x.x 200 pw-class test
ip route Virtual-PPP1
mchin345 Mon, 11/05/2007 - 15:15
Configure the Firewall to implicitly permit L2TP traffic and apply the access list checking in virtual interface depends upon your traffic requirements.
arun kumar Mon, 11/05/2007 - 21:33
Thanks for your reply. But the network im trying to simulate for one of our customer is where he doesn't have firewall. CPE will directly connect to our network without any intervening firewall. I just want to check any commands specfic (like "ppp idle timeout") be available so that i can make use of it... and provide accounting to the customers at times only he logs in..
