JVM Memory Requirement for CVP VXML Server
Oct 30th, 2007
I am trying to get to is the per element memory usage statistic. For example if I have a call flow with about 30 elements (for this discussion lets assume that there is minimum custom code), for example a prompter application for front ending, fetch data from DB and routing calls, I want to be able to use some type of formula that will tell me what -Xmx values to set at a minimum based on the CVP elements. Is there any type of profiling data that I can use to build a heuristic to get a ball park value for this ? To be precise, I would like to get a copy of our benchmarking/performance report for each CVP elements
smalkeric Mon, 11/05/2007 - 15:13
  • Silver, 250 points or more
You can allocate 1024MB : this will give more memory to the JVM.
For changing the vxml memory :
conf t
vxml tree memory XXXX
where XXXX is number of kilobytes to be assigned . You can increase or decrease the memory:
