Monitoring ONS chassis power failures
Oct 30th, 2007
I've had a power failure on a ONS chassis which wasn't noticed by CiscoWorks LMS 2.6. The system showed it as a minor alarm. How do I monitor these alerts?
show facility-alarm status:
System Totals Critical: 0 Major: 4 Minor: 1
Source Severity Description [Index]
Chassis MINOR Chassis power supply B failed [6]
htarra Mon, 11/05/2007 - 15:13
Can you capture the alarm logs and history for this node.
Let's check some more things.
1. Please retrieve the alarms by means of TL1 commands:
a) telnet 2361
b) > ACT-USER::UID:1::PID;
where: UID = user id (by default is CISCO15)
PID = password (by default is blank)
c) > RTRV-ALM-ALL:::2::,,,,,;
Please send me the output.
d) > CANC-USER::UID:3;
2. Could you load some default alarm profile from another ons which is fine?
a) You can do this from Provisioning->Alarm_Profiles->Alarm_Profile Editor, click
on load and choose a profile from other node that shows BAT-FAIL alarm.
b) Go to Alarm_Behavior tab and set the corresponding profile on Node_Profile, then
apply the change.
