Policy Based Routing / 4503 with SUP II + TS
ahmad-sajjad
Can i perform policy based routing with 4503 switch having SUP II + TS or i need to have router to perform this PBR? kindly provide links to the documentation if possible.
regards
ankbhasi
Hi Ahmad,
Sup2+ will support PBR only till 12.2(25)SG. Starting 12.2(25)SG the SupII+ will NOT work with the Enhanced (enterprise services)image which is required for PBR. Sup2+ has a smaller TCAM capacity.
http://www.cisco.com/en/US/customer/products/hw/switches/ps4324/prod_bulletin0900aecd8030c501.html
Please refer to the product bulletin..Look in Table 1.
Ankur
*Pls rate all helpfull post
hi Ankur
thanks for your reply. so that means,i cant perform PBR using this SUP engine.I need to have Router to perform PBR.
I need to route VPN traffic to specific path and MPLS traffic to other route.
thanks once again
Hi Ahmad,
Yes if your sup is running image which I specified in my previous post then sup2+ cannot do PBR and if you have a router then you have to use the router for the same.
Ankur
