PIX 515e VPN error
Oct 31st, 2007
im encountering error on PIX 515e. I tried to configure the firewall to be come VPN server using PPTP. When I tried to connect remotely, i recve this messge from the remote computer trying to stablish VPN. The error is, The Remote Computer is not Responding.
Any suggestions?
Patrick.Beaven Wed, 10/31/2007 - 11:21
Here is a template that i have used several times to enable pptp on pix's. Use it to verifiy you have everything enabled and setup correctly.
Good Luck,
P.S. The Cisco RAS vpn is much more secure and the client works on Windows and Linux!
cmadiam82 Sun, 11/04/2007 - 16:54
I already try to reconfig the PIX but still the prob is thesame. Anyone can help me pls...I need to make this one operational.
Tnx a lot guru's
ajagadee Wed, 11/07/2007 - 09:20
Can you post the configuration from the pix.
