Installing certificate on ACS Server
Oct 31st, 2007
i want to install the certificate in acs server, I have taken the option generate certificate signed request. configured all parameters like install ACS certificate, authority setup and trust list. the certificate has been generated and installed on the machine. But when i try to login to system it is working normally with http only. how can i change it to https. please anyone help me.
Overall Rating: 4 (1 ratings)
somishra Wed, 10/31/2007 - 02:19
  • Cisco Employee,
To Enable HTTPS for ACS :
Goto Administration Control -- Access Policy -- SSL Setup -- Use HTTPS Transport
To Create & Install a Server Certificate:
System Configuration -- ACS Certificate Setup -- Generate Self Signed Certificate -- Fill in the details -- Select- Install Generated Certificate
Restart ACS Services under Service Control
When you try to log into the ACS you would get a warning -- Select Yes
Tnx,
somishra
ralfdechent Wed, 10/31/2007 - 02:32
to use https you have to enable ssl for administrator access.
1. In the navigation bar, click "Administration Control"
2. Click "Access Policy"
3. Enable ACS to use SSL
BR
Ralf
