PA-A3-8E1IMA Support for G703
Oct 31st, 2007
Dear Cisco Team
Could you please clarify if the following port adapter in 7200 / 7500 can support E1 G.703 ( Unframed ) Configuration like PA-4E1G/120 without configuring ATM parameters
PA-A3-8E1IMA Eight-port E1 ATM port adapter with IMA
Thanking you in advance,
With Best Regards
Sundaram
Overall Rating: 4 (1 ratings)
paolo bevilacqua Wed, 10/31/2007 - 05:00
  • Hall of Fame,
    Founding Member
the PA supports unframed E1 ATM IMA. However, it can be only be used in ATM mode, not as a regular E1 PA.
hope this helps, please rate post if it does!
