7609S with redundant sup 720-3B
Answered Question
Oct 31st, 2007
We have 7609S with redundant sup 720-3B working fine with active and standby hot position.
Now I want to club both the sup's gigaethernet interface with same ip address.
Can I do this? if yes than how
please suggess me
Correct Answer by ankbhasi about 9 years 4 months ago
Hi Vineet,
You cannot have same ip address on both the interface individually but I believe you can configure layer 3 port channel and then assign an ip address to that port channel and finally bind both the gig interfaces to that port channel.
This link should guide you how to configure the same
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SXF/native/configuration/guide/channel.html#wp1020478
Try and update if it works for you.
Ankur
*Pls rate all helpfull post
Overall Rating: 5 (2 ratings)
Correct Answer
ankbhasi Wed, 10/31/2007 - 03:10
  • Cisco Employee,
Hi Vineet,
Ankur
