Jon Marshall Wed, 10/31/2007 - 05:12
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Have a look at these 2 documents which are Cisco Best Practice recommendations for CatOS and IOS switches. They include recommendations on etherchannel configuration amongst many other things.
CatOS
http://www.cisco.com/en/US/products/hw/switches/ps663/products_tech_note09186a0080094713.shtml
IOS
http://www.cisco.com/en/US/products/hw/switches/ps700/products_white_paper09186a00801b49a4.shtml
Jon
welcomeccie Wed, 10/31/2007 - 06:35
Thank you very much for your reply But they didn't state if i should use ON or desirable mode for etherchannel .There is no recommendation for my question
Jon Marshall Wed, 10/31/2007 - 06:42
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Are you talking about layer 2 or layer 3 etherchannels ?
From CatOS doc
Recommendation
Cisco recommends that PAgP be enabled on all switch-to-switch channel connections, avoiding on mode. The preferred method is to set desirable mode at both ends of a link. The additional recommendation is to leave the silent/non-silent keyword at default - silent on Catalyst 6500/6000 and 4500/4000 switches, non-silent on Catalyst 5500/5000 fiber ports.
From IOS doc
Cisco Configuration Recommendation for L2 Channels
Enable PAgP and use a setting of desirable-desirable on all EtherChannel links
Jon
