STP functionality
Answered Question
Oct 31st, 2007
Hi everybody,
only a doubt about STP (802.1d).
Suppose to have a simple loop between three switches (in purely daisy chain).
What if one of them (say SWA) doesn't support STP?
Can I use STP nevertheless ?
The other two switch are able to manage the port block/forwarding algorithm, so mantaining connectivity without looping ?
Thank you in advance
Correct Answer by Kevin Dorrell about 9 years 8 months ago
It depends on whether the third-party switch passes the BPDUs through transparently. If it does so, the STP will block a port to prevent the loop. It would be as if you had a crossed-cable instead of the third-party switch.
If it doesn't, then the network will meltdown.
Kevin Dorrell
Luxembourg
Overall Rating: 5 (1 ratings)
Correct Answer
Kevin Dorrell Wed, 10/31/2007 - 05:17
  • Green, 3000 points or more
Kevin Dorrell
Luxembourg
