CCME to External Gateway Example
Oct 31st, 2007
I have a 2811 router running CCME/CUE along with another 2821 router that has a PRI circuit. I have my phones registered to the CCME and I can make calls between them but I am new to this and I was hoping someone would know of some examples of how to get my phones to use the PRI on the 2821.
Overall Rating: 5 (1 ratings)
paolo bevilacqua Wed, 10/31/2007 - 05:05
  • Hall of Fame,
    Founding Member
On the router without PRI:
dial-peer voice 100 voip
destination-pattern 9T
session target ipv4:
dtmft-relay cisco-rtp
Calling 9 they will get to the other router. Of course choose a same digit for calling out.
h.parsons Wed, 10/31/2007 - 05:11
What about on the router with the PRI, how do I route incoming calls to the phones?
paolo bevilacqua Wed, 10/31/2007 - 05:19
  • Hall of Fame,
    Founding Member
You don't need anything on the terminating. Just configure an additional voip DP on the originating, with eg destination-patter 7... and using the same session target.
