API for Cisco routers
bipin_dubey2001
how can we make a software application talk to cisco routers. Is there any API using which the same can be achieved.
There is an API but for XR series IOS .
We need to communicate with Cisco 2811 routers using an application.
Any tips on this would eb extremely useful
rolf.fischer_2
I'm not sure what exacly you want to achive but it sounds like SNMP could be a solution?
Rolf
Thanks for the update Rolf but we have already considered using SNMP.
As far as your query is concerned we are trying to create a software application that can configure routers.
Bipin
David Stanford
Depending on what you want to do, you could use something like CiscoWorks LMS for configurations (netconfig, config editor)
