Port Security on 180x routers
Oct 31st, 2007
1801 with 8 port LAN routers were deployed as part of managed WAN. We've asked them to turn on port security. They said it wasn't supported. Does the 180x LAN ports have same port security features (i.e. MAC address learn/lock) like standalone switches?
Edison Ortiz Wed, 10/31/2007 - 07:18
  • Hall of Fame,
    Founding Member
HWIC-D-9ESW is the 8Port EtherSwitch module you are referring to
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_feature_guide09186a00802c6bb6.html
From the Layer2 switching link on that page:
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_feature_guide09186a00801d2d60.html#1048478
It refers to port security support, so I believe it does.
mschlenker Wed, 10/31/2007 - 11:07
Thanks for the update. I should have been more clear. The 180x routers are fixed configuration units not modular.
Edison Ortiz Wed, 10/31/2007 - 11:33
  • Hall of Fame,
    Founding Member
8Port LAN fixed ? Hmm.. Do you have a part number on that ?
Can you try and see if it takes the port-security commands ?
mschlenker Wed, 10/31/2007 - 11:52
The part number is the 1802. Do not have access to the router. It's part of managed WAN service and we are locked out of the command line.
Edison Ortiz Wed, 10/31/2007 - 12:27
  • Hall of Fame,
    Founding Member
I searched and couldn't find any information regarding that model and port security support.
