VPN Client Suport
Oct 31st, 2007
is Cisco VPN Client 5.0.00 support PPTP.?
i have been given PPTP VPN credential, didnt find any option in to my VPN Client saying PPTP, it only shows IP Sec over TCp/UDP.
Dhaval Tandel
JORGE RODRIGUEZ Thu, 11/01/2007 - 12:22
  • Green, 3000 points or more
Hi Dhaval, PPTP is the client used by Microsoft windows. In your windows workstation network connection you "create a new network connection “ then “Connect using VPN " this will setup the pptp client.
Cisco VPN client is the software you download from Cisco and install in your workstation both PPTP and Cisco VPN client are totally different and separate vpn clients from each other in the sense of using different ports and protocols .
installing Microsoft pptp
http://msdn2.microsoft.com/en-us/library/ms811078.aspx
Please rate helpful posts
Jorge
