L2TP - can the same pool be used by 2 differnet LACs?
Oct 31st, 2007
I have a question in regards to L2TP... we currently have one LAC configured on our LNS, and are in the process of setting up a connection to a second LAC.
Can the second LAC use the same virtual-template as the first, and can they share the same pool?
Thanks!!
Lisa G
We have an LNS which has 2 separate LACs... can each
vpdn-group Default
! Default L2TP VPDN group
accept-dialin
protocol l2tp
virtual-template 1
no l2tp tunnel authentication
l2tp tunnel framing capabilities all
l2tp tunnel bearer capabilities all
ip pmtu
ip mtu adjust
vpdn-group GUAMCELL
accept-dialin
protocol l2tp
virtual-template 1
terminate-from hostname lac2
local name guamcell
ip pmtu
ip mtu adjust
interface Virtual-Template1
ip unnumbered Loopback0
ip mtu 1400
ip policy route-map clear-df
peer default ip address pool guamcell
no keepalive
ppp authentication chap
ppp ipcp dns 63.103.50.15 63.103.50.16
ip local pool guamcell 116.68.11.1 116.68.11.253
irisrios Tue, 11/06/2007 - 11:15
  • Silver, 250 points or more
No, You cant have same virtual template for both the NAC. Virtual templates differ.
